Eclipse head unit output voltage ?
DirtySouth
Need some help here please. I'm interested in purchasing an eclipse h/u, probably the 8445. The thing i'm worried about is the 8v preouts. I am going to run a Merlin MD2 and and the max input voltage on the amp is 6v. Will these be compatible? I've looked online and can't really find a straight answer. I've read the higher output voltage won't hurt anything, but will cause the amplifier to clip. Is this a true statement? Does anyone else run a h/u with a higher output voltage than what the amplifier is rated? I want to hear especially from the eclipse guys. What kind of results have you had? Should I forget the eclipse and go with another brand with less preout voltage?
Thanks for your help.
DirtySouth
DirtySouth
Tulsa
faulkton
Mike Mccabe
