headless
Hey all. I've currently got an Eclipse EA3422 amp pushing my Rainbow Germanium CS265 components... i've got it set up as a 4ch configuration from my CD8454 so i can adjust time alignment on each channel independently. I'm using the passive X-over's and bi-wiring them from the same amp (it's got inputs for bi-amping). The setup is working well but i know that the EA3422 is rated @ 2x140rms if set for 2ch mode, vs. 4x50w RMS in it's current 4ch configuration -- so i wanted to give that a try. I'm good to go with re-wiring the x-over's to the correct connectors on the speaker wire connector block area...but i am wondering about a couple of things otherwise.
1. Currently my RCA's are:
(DECK)HIGH L+R outputs (AMP)FRONT L+R inputs TWEETS INPUTS ON X-OVERS
(DECK)MID L+R outputs (AMP)REAR L+R inputs WOOFERS INPUTS ON X-OVERS
When i change the amp to 2ch, the front and rear channels turn mono..so i will change the rca's to this (i think)?
(DECK)HIGH L output + MID L output (AMP)FRONT L INPUT + FRONT R INPUT TWEETS + WOOFERS INPUTS ON L X-OVER (mono)
(DECK)HIGH R output + MID R output (AMP)REAR L INPUT + REAR R INPUT TWEETS + WOOFERS INPUTS ON R X-OVER (mono)
Is this correct?
Next; can i leave my time alignment settings for my mid-l, mid-r, high-l, high-r, etc. on, and still see the benefit through this configuration? If my time alignment doesn't work bridged down like this, i think i may not switch. I might have to get another amp in there and bi-amp the rainbows..
Any responses would be appreciated. Please don't hurt me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Is this correct?
