Sold Eclipse cd8454
shirkmac
I have two eclipse cd8454's for sale one is brand new never used or mounted and other is in used but mint condition. Purchased in Toledo at car stereo one. Everything that I bought with it will be included: original box, manual, nob remote, mic, memory card, harness, etc. ESN was never activated. Looking for $350 + shipping OBO for never used one and 300+ shipping for used. Feel free to ask any questions and thanks for looking. My email is shirkmac2@hotmail.com
These are some pictures of the units
Here are some specs:
The flagship unit in the new CD Receivers, the CD8454 sets a new standard in audio-dedicated music reproduction for the mobile environment. Whether the program source is CD, CD-R/CD-RW, MP3, radio broadcasts or even WMA files on a Memory Stick, sound quality is always exceptional. Music takes on the effortless quality that is the hallmark of the best audio components.
* High Preamp Output Voltage The CD8454 circuits deliver a very high preamp output of 8 volts to help lower system noise and increase system dynamics since the power amplification stage can be driven optimally. The output signal’s low impedance of 55 ohms is also electrically ideal for audio signal transfer.
* Full-dot Vacuum Fluorescent (VF) Display This display makes best use of the space available with alphanumeric characters that retain high contrast in all light conditions. Brightness levels can be set to suit user preferences for day and night driving conditions and illumination can be switched from green to red. A graphic assist function helps confirm parameter changes.
Specifications: NOB Remote Control CD Changer Control CD-R/RW WMA MP3 Digital Servo System (DSS) TUNER STARTUNER® V Station Name Input AUDIO Output voltage and impedance 8V 55 Ohm MOSFET Amplification All digital circuitry 24-bit DAC DSP with Time Alignment, Parametric EQ, Crossover Electronic Crossover Control Non Fader Pre-out Dual Pre-out Digital Input Digital Output (for E-com) AUX In MEMORY STICK ATRAC3 Decode/Encode E-iSERV Connection Memory Stick ESN GENERAL ECLIPSE Security Network Display VF (Full dot) Full Face Tilt Bright & Dimmer Control ECLIPSE COMMANDER ADVANCE ready E-LAN data link system Current Drain 3A Dimensions (W ×H × D) 7" × 2" × 6-1/8" (178 × 50 × 155mm) FM TUNER Frequency Range 87.75 ~ 107.9 MHz (200kHz step) Usable Sensitivity 13dBf 50dB Quieting Sensitivity 14dBf Frequency Response 30 ~ 15,000Hz, ±3dB Stereo Separation 38dB (1kHz) AM TUNER Frequency Range 530 ~ 1,710kHz (10kHz step) Usable Sensitivity 20µV CD SECTION Frequency Response 20 Hz ~ 20,000Hz, ±3dB Wow & Flutter Below measurable limits Stereo Separation 85dB S/N Ratio (A-weighted) 100dB Dynamic Range 98dB Total Harmonic Distortion 0.01% AUDIO AMPLIFIER Power Output 13W x 4 (20 ~ 20,000Hz, 0.8%THD, 4Ohm) - MAX 50W x 4 Lineout Output Level/Impedance 8V(0dB)/55 Ohm Tone Control Bass +12dB at 80Hz Treble +12dB at 10kHz Loudness +10dB at 100Hz/+6.5dB at 10kHz MEMORY STICK PLAYER SECTION Frequency Response 20Hz ~ 20,000Hz, ±3dB S/N Ratio (A-weighted) 100dB Total Harmonic Distortion 0.01%
shirkmac
shirkmac
macedonia,oh
BassBallin
