Eclipse CD8454 is ****
I have to insert a reglar disc, then stick in a burned one....
I use Itunes to burn the discs (CDR) and they are not accepted. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
CDR burns are like an audio cd that is universally readable...
you can also burn in MP3 off of itunes and it won;t read it.
I did not secure the externl brain, i just left it behind the dash loose...
Ok - you're using iTunes as your utility to burn .cda files then. I read it simply as you're using iTunes to burn to CD-R media (as everyone is either using CD-R or CD-RW discs it never occured to me you meant something else)
As I have no experience with Eclipses HUs I don't know if the external brain not being mounted solidly would have anything to do with your issue but I can't imagine it being a good thing having it rattling around loose behind the dash...
Hitting the reset problem solved my 8454's problem reading burned CDs. It will clear all of your settings though, so you might want to write them down.
I changed my battery recently and lost all lthe settings, and it still won't read CD-Rs.
Whurr is the reset button? //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
apple/itunes sucks. get roxio and i bet u never have another problem //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It's on the front. A little hole you have to push a paper clip into.
My GF's burned a few discs from iTunes and they work fine on mine.
I like iTunes. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
It is teh shexxor.
LoudCrownVic
1/1 of Team Team Team
LoudCrownVic
Scales Bump, IL
LoudCrownVic
