Installed the h/u today and spliced all the wires going by the colors in the booklet to the wires in the old wire harness "had the names on them"
and hooked the amp rca's to the "no-fader/low" rca out
everything worked fine at first till we put a rap song for about 10 seconds then it went into protect till we turned off the h/u and when it turned back on, the sub was fine.
went back into protect when a bassy song was played again
checked ground, remote turn on, heat, rca's and unhooked the sub.
-when the sub was unhooked, we played a tone ~50 hz and it went into protect after about 30-45 seconds
So basically its either the wiring, amp or some messed up signal coming from the h/u
Any help is greatly appreciated -Jimmy
