Ebony & Ivory.... some of ZED's best.....
Louisiana_CRX
dem shoes......
Rare pair of mint ZED Audio made Planet Audio Tube Amps....awesome tube SQ.....pretty sweet pair of amps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
They are 1ohm stable amps...they'll do about double that at 2ohm bridged...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Not unless they do double rated power. They are rated for 260w bridged at 2 ohms (granted, I wouldn't be surprised if they were grossly underrated depending on how old they are)
I think these are better suited for SQ of mids and highs over subs anyway...they are probally under rated by as much as 50% I believe they were gonna originally be rated at 75 x2 but ended up rated at 50 x 2 which I think is a 12v rating....so they could be used in SQ when lower power classes were set years ago in car audio....I think this would make a nice bi-amp setup for a high quality front stage //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Would definitely be nice for an active front stage. Should redo the system in the Tacoma for SQ now that you tore stuff out to put in the Tundra.
I traded the Tacoma in on the Tundra...The Tacoma was nice but the V6 didn't have enough power to pull my Dozer safely...The 5.7 in the Tundra has over 100hp more than the Tacoma and over double the towing capacity...even with the heavy duty tow pkg on the Tacoma.....I'll loose about 5 mpg which will **** though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I had the white one for sale a while back then I stumbled across its black twin....so I decided I'd keep them since they make such a cute couple //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif probally something deerhunt wouldn't understand.....
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
