There are nearly 300 video formats around us, but the commonly-used video formats are only about 30 like avi, mov, mp4, vob, swf, flv, 3gp, 3g2, mkv, rm, xvid, mpg, mod, m4v, mts, rmvb, wmv, asx, etc.. Various portable players and windows media players support limited video formats. So it always brings inconvenience to you.
For exaple, you have a new iPod (mp4 and H.264) and you cannot put mov, flv, or mkv formats on it. Therefore, it need conversion between these video format in order to be suitable for all players.
Tipard Video Converter is one of the most popular converters among people. It is upgraded with newest core technology. It can convert video between these common video formats. The video converter is very easy to for everyone.
How to convert video with this converter:
Step 1: Download and install Tipard Video Converter
Step 2.Click the "Add File" button to load video file.
Step 3. Video settings
Select the output video format you want from the drop-down list of profile.
Note:
By cicking the "Settings" button, you can set the video parameters and audio tract.
step 4.Click the "Start" button to start conversion. It is very fast and in a short while your conversion will be finished.
The video converter can edit video with effecting, trimming, cropping, adding watermark, merging clips into one file, setting video parameters, selecting audio track and subtitle.
★Watermark★
By clicking “watermark” you can add text or picture watermark for your video according to your need.
★Effect★
Click “Effect” button you can do these actions: adjusting brightness, contrast and saturation of the video. You can easily adjust the video through two windows in the same interface.
★Trim★
If you just want convert a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the slide bar to the accurate position.
★Crop★
By using the “Crop” function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to your Google Phone.
The conversion is quickly completed with good output quality.
Note:
Tipard Video Converter is at discount now and you can get one easily.
Note:
★Watermark★
★Effect★
★Trim★
★Crop★
Note:
