Earthquake HoLeeS
Rodge
Anyone know anything about this sub? My friend just spent an assload of money for it and an earthquake 10000W mono block. I think it's kind of a joke seeing as how he spent nearly 4K on the sub and amp alone. Oh yeah, he's not even going to compete with this. I have no clue why he bought it and thought it was a pretty big waste of cash. Seems like he could of spent half of what he did and still had one hell of a sub stage. He already had two 15" Earthquake DBRs
4large on one sub and one amp...... omfg... thats a buttload of money to spend...... specially for not even competing.. sorry for not knowing a dam thing about the sub... but i just had to comment //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hey coulda spent a 1/4 of that and owned that woofer //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
wow.... can I be your friend's friend too?
# Ruler of DBDragg
# Now more than ever the name Earthquake has become synonymous with winners circle, ruler of DBDrag, the one to beat etc. For 2005 we elaborated on the bar and raised it so high it wont be touched exceeding even our best.
# The HoLeeS-15 competition subwoofer weighs in at 100lbs. net. It packs four superior spider units, a 4" dual voice coil with a flat wire surface, patented PSP terminals, a high roll surround and killer looks.
# If your ready bring home 1st place your at the right place. If your using anything else you'll just get second and be the first looser
# SPECS
# Sensitivity 85.0 dB
# Qts .338
# Fo 25.475 Hz
# 15,000 Watts Peak
# 7000 Watts RMS each coil
# Over 4" long throw excursion
# Dual (2x1ohms) 4" x 8" High Temp military grade flat wire voice coil.
# (4)Quad Nomax / Romax spider construction
# 8 gauge speaker connections
# 112lbs.
# Reccomended Enclosure
# 6-10 Cu Ft 1" MDF Minimum
# Port Surface 107.25 sq in
# Port Length 18.5" Depending on the tuning frequency
# Ruler of DBDragg# Now more than ever the name Earthquake has become synonymous with winners circle, ruler of DBDrag, the one to beat etc. For 2005 we elaborated on the bar and raised it so high it wont be touched exceeding even our best.
# SPECS
# Qts .338
# Fo 25.475 Hz
# 15,000 Watts Peak
# 112lbs.
The thing looks pretty beastly. Problem is it probably won't get loud until you put a ton of power to it. Say the amp he bought does 4-5k rms, it's gonna pull mass amounts of current. If that's all he bought, he'll fry the amp from low voltage before he gets the power out of the amp.
if thats the case y i dont see any of there subs breaking records or winning trophies?
what a crappy marketing tool
# SPECS
# Qts .338
# Fo 25.475 Hz
# 15,000 Watts Peak
# 112lbs.
i can put money that a mt or even the ia wardens will own it
80
This is really pissing me off now. I get a call from him yesterday. My truck broke down and I want to get my box and amp out so it doesn't get stolen. Ok no problem. We get there and I realize how shitty of a job he did putting the box together. He took the port divider out, so basically it's a big box with a slot port hole cut in it. It seems like it's the right size, but **** the box is horrific. Then to make things worse he had to rewire the sub to 2 ohms because at .5 ohms it was killing his, stock, YES STOCK, electrical system. I don't even want to bother getting pics because he just isn't doing this speaker any justice. **** I wish he would of just listened to me in the first place. I can see it already, I'm gonna get a ton of calls from him because he can't figure out why his shit isn't loud.
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Rodge
Rodge
Mohnton, PA
Rodge
