absalom
Vehicle: 2010 VW Jetta Sportwagen
Symptoms: Painful treble at mid-to-higher volumes. Muddy, unclear treble. Very little apparent midrange. Cold overall sound.
My build:
Boston Acoustics SR60 Components (Front & Rear)
Orion XTR2504 4 channel Amp - 50w @ 4ohms (x4)
JVC KWNT3HDT Navigation Headunit
Story:
I purchased the vehicle about a week ago. When purchased, there was an 8 each sub bridged on channels 3&4. The 4 speakers were spread out between the two remaining channels on the amp. At this stage, the sound was punchy but highly unpleasant due to the muddy, earpiercing treble.
I chalked it up to bad wiring and poor tuning. So I reset everything to "zero" or "flat" and removed the sub (temporarily) from the system. I then gave each door it's own channel on the amp. I also set the tweeter attenuation to max on each individual tweeter crossover.
With the sub removed, I've lost my low end, and still suffer from the same terrible high end notes. It's downright painful at mid-to-high volumes.
My Question:
Is there a setting I'm missing? Are the SR60 components just shoddy speakers? Which single piece of my system can I replace to remedy this problem?
My build:
Story:
My Question:
