DynAudio MD102 tweeters.
got-one-eight
Used for about 4 months after I had a morel tweeter go out. I really hate to part with these things but right now they have to go. They are in perfect shape and really sound amazing. So far the best tweeters I have owned with the Morel not far behind.
Thiele Small Parameters
Nominal impedance Znom 8 Ω
DC resistance Re 5.6 Ω
Voice coil inductance Le -mH
Resonance frequency fs 1300 Hz
Mechanical Q factor Qms -
Electrical Q factor Qes -
Total Q factor Qts -
Mechanical resistance Rms -kg/s
Moving mass (incl. air load) Mms -g
Suspension compliance Cms -mm/N
Effective dome diameter d -mm
Effective piston area Sd 7.7 cm²
Equivalent volume Vas -l
Force factor Bl -Tm
Recommended frequency range 2200 - 30000 Hz
Magnet and Voice Coil Properties
Voice coil diameter dc 28 mm
Voice coil height hc 1.7 mm
Linear excursion, peak to peak -mm
Max. excursion, peak to peak -mm
Power Handling
Nominal long term IEC (Depending on crossover) 100 W
Transient (10 ms) 500 W
Mechanical Properties
Net weight 0.126 kg
Overall dimension ø 62.2 x 43 mm
SOLD SOLD SOLD!
Shipping Cont. 48 states
References in signature and heatware under Copyright21
I played with them from 2.5 to 4khz.. I think around 3khz they sounded best in my setup. I really didn't have near the power they can take but they sounded amazing. It's a different sound compared to any tweeter I have heard.. very smooth.
got-one-eight
got-one-eight
Houston, Tx
got-one-eight
