dynamat
Originally posted by i3abyjay25 how much help is dynomat and sound deaden in a car w/ a system that hits over 150
Sound deadening will help you with your SQ, and will keep SPL in..thus making it a little bit louder in your vehicle, after installation. Sound deadening will also drastically reduce road/engine/exhuast noise.
- Steve
Sound damping is by far (IMO) the most important part of any quality install.
I am surprised a lot of the shops around here don’t push it more than they do.
They install $15,000 systems with no damping?!?!?!?
Makes no sense to me
Most materials are the same.
Usually a high temperature mastic, (dynamat original) or a bituminous based tar with an aluminum heat shield. (Dynamat Extreme, brown bread, P&S etc)
On average they are 45 to 60 mils thick and all do the same job. Here is the catch, the thicker the material the less sticky it becomes. This is true with most all bituminous based materials.
Also, some materials have higher temperature ratings.
The higher the temperature rating, the less sticky, BUT!!!! The lower the rating the more likely it is to fall of due to heat.
It is a difficult task of combining the ingredients to come up with the perfect balance of adhesive strength and temperature tolerance.
That is why dynamat has a patent on their material. They have a heat rating of 300f and still have a super adhesive product.
Most other materials only go as high as 225.
But, that’s also why Dynamat charges so much for their material.
Now, if Dynamat were to make their Dynamat extreme 60 mils thick instead of 45 mils thick it would not be as sticky and would not work as well (with out lowering the heat tolerance)
When I had Second Skin Damplifier made, I had to take all of this into consideration. What an arduous task.
Anyways, check out these products that are proven to have good temperature ratings and strong adhesive strength:
Rammat, B-quiet extreme, Brown bread, Fatmat, Dynamat extreme, and Second Skin Damplifier.
Hope this helps
ANT
Uh, ANT, is it a good thing...that I cant even pull the mat back? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
- Steve
yeah
Wait untill it gets hot outside though
I will bunch easier to pull off. not easy, but easier.
thats why I dont reccomend DampX for upside down surfaces. when it gets hot it getts less stcky, and since it weighs so much anyways its just a bad combo.
it is the closes I can get to dynamat extreme without violating thier patent.
dynamat has a great product but gets knocked for the prices they charge.
oh well,
big mike 1980
big mike 1980
buena park
ss3079
