Dynamat ex vs Damp pro
Exactly... Damplifier is like Dyanamat Extreme. Damplifier Pro is in another world compared to just about anything.
Just as a random example of the adhesive properties of Damplifier... I had a small leak coming from the transmission housing on my 94' Civic when it was still running. I cleaned it well then stuck a piece of Damplifier (regular) on there -- which actually did slow it down. Four months later when I was taking the engine out to build for boost... still on there =)
Which is best Dynamat Extreme vs Damplifier Pro, They both cosr about the sameDamplifier Pro cost a little more Dynamat extreme is at 120.00 delivered 35ft
on ebay, I read here members from caraudio.com can get 20% off,is this still valid?
dont believe they are still valid.
I did however install 200+sq feet of Damp Pro in my last car and I had no trouble with it. Its amazingly easy to work with and amazingly effective. I probably will buy regular Damp. for now though, my wallet's not as full. Overall, both great to work with.
Thanks for all the kind words guys. I didn't realize there were so many Second Skin fans still on this board!
Dynamat Extreme is a great product. With the exception of our higher heat rating and slightly thinner foil, regular Damplifier Compares very well. about 17/100mm thinner is all.
Damplifier Pro on the other hand is about 20 mils thicker and has the same high heat rating that regular Damplifier has; 500 f.
If anyone has any sound deadening questions feel free to call me
800-679.8511
I am always happy to help, whether you use our vibration damper or not.
ANT
Second Skin
Dynamat Extreme is a great product. With the exception of our higher heat rating and slightly thinner foril, regular Damplifier Comares very well. about 17/100mm thinner is all.
800-679.8511
ANT
second skin
Guys,
After reading your comments about Damp Pro, I found Anthony's shop since I live here in AZ. Talked to him on the phone, he hooked me up and took care of me. Seems like an awesome deal and great guy to do business with. Got everything I needed, and even sent me to one of his shops for speaker wire.
Thanks Again Anthony!! //content.invisioncic.com/y282845/emoticons/yourock.gif.93d527d504392657a77fa577298070a1.gif
Guys,
Ive spoken with Anthony many times, Ive never been less than impressed and thoroughly satisfied with his handling of his business.
Guys,
Glad to hear that they took care of you.
Also happy that you like our stuff.
Let me know if you need anything else!
ANT
Second Skin
yuppp second skin is awesome. ant is always quick with the responses if you need the help. used damp pro inside the car and spectrum on the outside like ant told me to do and my car is much more quiet now
DoubleBass07
DoubleBass07
san francisco
XaznKewLguyX
vegang
vegang
