elementxero
Not an 06'er.
Alright. I found out something odd while setting my gains but this isn't related to gain setting so I made a new thread:
I have had bad vibes from this amp since I bought it here, but I don't want to assume anything.
Here's the deal:
The amp makes a very odd hissing/humming sound that doesn't sound like a fan.
The amp produces almost ZERO sound output with the head unit at 28/35 and the gain up 1/3 of the way.
The seller said that he always had the gain at zero. The reason is because he had what he kept calling a "bass module" which amounted to a phone jack plugged into the remote bass plug with a plastic tube on the end. What's hooked up in there is anybodys guess.
With this 'module' plugged in, the output is suddenly heavy even at a zero setting.
Now, and here's where it gets sketchy, when I take an AC Voltage reading from the + and - output terminals, the meter reads anywhere from 60 to 190VoltsAC, regardless of gain!
It doesn't remain static either it jumps rapidly around in that range. I'm definitely probing the same metal that my speaker wire connects to, and the meter works fine as I set my RF2002's gains perfectly smoothly right before this.
So, my theory is that this amp is as much of a POS as it looked when I got it. If this is the case its paypal investigation time.
Thoughts?
ps- excuse the long post but I'm kind of heated at this point and I want to make sure I don't jump to conclusions.
Here's the deal:
Thoughts?
