DVC wiring!!
RedSox817
Ok i Have 2 10" reference series infinity 1052w DVC 4ohm subs with 250w RMS and 1000w peak and an audiobahn A8002T 2 channel 800w coming in the mail soon.....now i think it was a mistake getting the amp but maybe i just dont understand wiring correctly....a parallel hookup wil rum 1 ohm to the amp which the amp can handle 2 ohm so that will cook my amp to crap if im not mistaken....series wiring wil not pump enough to power the subs....so what im wondering is is there a way to wire them to still?am i wrong?or sould i get a different amp? im new to this so any help will be appreciated thanx here's the info-
Audiobahn A8002T-
200 X 2 at 4 Ohms Stereo
400 x 2 at 2 Ohms Stereo
800 x 1 at 4 Ohms Mono
Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-double Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 50Hz to 120Hz
Bass Boost On/Off
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
1-Year Warranty
Infinity Ref 1052W
Polypropylene Cone
Large-Roll Butyl Rubber Surround
Unique Inboard Motor Structure
Bumped Backplate
Vented Polepiece
Progressive Spider
Proprietary Reduced-Depth Steel Basket
Cutout Diameter: 9 1/8"
Mounting Depth: 4 9/16"
Subwoofer Specifications
Rec. Sealed Box Dims: .75 - .75 cu.ft.
Rec. Ported Box Dims: 1.75 - 1.75 cu.ft
Free Air Usage: not recommended
Sensitivity: 91 dB
Frequency Response: 25-400 Hz
Recommended RMS Power: 250W
Peak Power Handling: 1,000W
Impedance: dual 4 ohms
RedSox817
RedSox817
rhode island
RandyJ
Mike Mccabe
Giles
    Jun 27, 2026
