Sold Dual XIA3145 amp 290 RMS watts
slim2fattycake
rolling right along
The Dual XIA3145 is the perfect entry level amplifier for those just beginning to replace their factory system. The two channel amplifier will produce 145 watts RMS at 2 ohms or you can bridge the two channels together to result in a 290 watt RMS output. The XIA3145 has a max output of 580 watts through a single bridged channel. This amplifier is also compatible with Dual illuminite speakers, which shine an impressive blue hue. With a price this low, it is hard to go wrong.
* Dual XIA Series 2-Channel Class A/B Car Amplifier
* RMS Power Rating:
o 4 ohms: 100 watts x 2 chan.
o 2 ohms: 145 watts x 2 chan.
o Bridged, 4 ohms: 290 watts x 1 chan.
* Max power output: 580 watts x 1 chan.
* MOSFET power supply
* Bi-color LED status indicator
* Tuned Bass Boost (0-12 dB bass boost at 45 Hz)
* Illuminite circuit output
* Thermal overload protection
* Auto-reset speaker short circuit protection
* Reverse polarity protection
* Die-cast aluminum heatsink
* RCA level inputs
* screw terminals
* Variable high-pass filter (40-400 Hz, 24 dB/octave)
* Variable low-pass filter (40-400 Hz, 24 dB/octave)
* CEA-2006 compliant amplifier
* Frequency response: 20-20,000 Hz
* Dimensions: 9-3/4"L x 16"W x 2-1/2H
* 8-gauge power and ground wiring is required for installation.
50 dollars shipped 48 states. I don't have the metal top anymore because someone tried to steal it and could only take that off and not the amp so yea. The amp is in great condition still mechanically and cosmetically. You can use on some speakers or subs.
slim2fattycake
rolling right along
slim2fattycake
In the Stars
slim2fattycake
