Dual 4ohm 15" for Home Audio System
JayRich
I'm looking for a 15 dual 4 ohm woofer around $150-$170 That has good sound quality, gets low and would work well off of 300 watts from my crown comtech 200 amplifier. I'm looking at getting a brahma but if you have anything else that may sway my decision feel free to hit me up
Thanks for the info, I know its an 18 but would it get anywhere as low as the brahma, I'm looking a alot of low end. It will be in a basement with the walls deadened and no house around for 1000 feet :)
doubt it will have the low end of the brahma.
are u still looking for a brahma?
my buddy has a mk1 15 but its d2. but if u have a plate or rack amp they work better on 4ohms. lmk i can get it for cheap //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
doubt it will have the low end of the brahma.are u still looking for a brahma?
yeah im still looking, found someone on ebay selling the mkiv for $150 but $80!!! Shipping and handling. I have a crown comtech 200 that puts out its most at 8 ohms bridged (300 watts)
http://www.tvprogear.com/product/Crown-Com-Tech-200-Power-Amp,727,545.aspx
Dual mode(with both channels driven)
150 watts into 4 ohms
110 watts into 8 ohms
110 watts with 70 volt output
Bridge-Mono mode
300 watts into 8 ohms
220watts into 16ohms
205 watts in 70 volt mode (140 volt output)
Parallel-Mono mode
295 watts into 2 ohms
220 watts into 16 ohms
210 watts with 70 volts output
Soundsplinter 15" RL-p? Its Dual 4 and a solid performer. Cone has some discoloration from time, but works perfect. Was saving it for a sub to go with my computer in my den but its ava. Here are some pics,
Normally I dont care about how the sub looks cosmetically b/c it would be in my trunk, but for my HT system it is important to me as it will been seen at all times. Thanks anyway
JayRich
JayRich
Richmond, VA
JayRich
