---------Dual 4 or dual 2 and other suggestions/help---------
sound giant
So ive decided to just go with one alpine type R 12 in the ported box, i was planning on using a hifonics amp, the bxi1208d. I was just wondering do you think that amp is ok and if so then which type R should i buy, the dual4ohm or the dual2ohm. The amp is 1 ohm stable so i was thinking i should wire it for 1 ohm and just adjust the gains. How does that sound? Also I was thinking would i need a cap? I was going to go with a 2 farad cap, something like the cheap boss capacitor. Then i would need wiring and be good to go. I have an alpine 9883 and Arc fd4625 up front maybe an Arc amp for the front too. This is just a lil setup to upgrade from stock, nothing fancy. I wanted to get some fill for the ported box too, any suggestions would be apprieciated guys. thanks in advance.
so wait on the cap? i think i got one of the yellow everstart batteries. D2 is better for 1 ohm, can D4 go down to 1 ohm? THe reason i ask is I can get the D4 for almost $30 cheaper.
refresh my memory the big 3 is....alternator, cap, ?
D4 can not be wired to 1 ohm,only 2 ohms,the D2 wired to 1 ohm will be a lil louder than D4 wired to 2 ohm,guess you could get a cap if you want something to look pretty,they really are a waste of money.big 3 is alt,engine to chassis,batt ground to chassis
firget about the cap, a waste of money, use that money to get a good batt fr under the hood. Do the big 3 like they said. And if possible get 0awg wire. 4aw wouldwork but u might as well and get 0 just incase o u ever upgrade again. BTW A guy on thi forum has 2 Type R 12s on a IA 40.1. Each sub is seeing about 1600watts rms so yea, the hifonics sould do fine with the sub. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sound giant
sound giant
Aiea, Oahu, Hawaii
sound giant
