Dual 3 High Temperature BAEISV Voice Coil vs 3 4-layer aluminum voice coil
  • 6
Uhhhh......huh? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
somebody told me to look at coils when trying to pick a sub.. the question if you didn't guess was what is better
im trying to decide between two speakers that are pretty much the same in rsm but voice coils are set up different im asking out of the two choices is there anyway to tell what is better
well, it's like "full-size blazer vs. 22" rims. which is better?" dual 3 is the impedance configuration, and 3, sounds like 3" diameter. i think what you were directed to look at was the impedance configuration, and power level, to match your amp. i'm taking it you are comparing a jl w6/7 to something else? not many d3 subs out there. if you have a 1.5ohm stable jl amp, then it would kind of match. however, some amps, you loose a little rms at 1.5, and some you don't. what is the configuration of the aluminum coil? what sub is it?
740
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
752
854
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
PIMPSLAPN
PIMPSLAPN
MI
PIMPSLAPN
    Apr 28, 2024
    Apr 28, 2024
