Does your head unit affect your overall sound system for amp and subs
Hey I was wondering if having a low wattage head unit will be a noticeable difference in amp and subwoofer performance? I just recently had a jensen vx3010 installed and it doesn't seem as loud as my factory unit in my 03 monte carlo the watts on it is 40 x4 watt max and 13 x4 rms I'm looking to get my 2 kicker 12 cvrs and rockford Fosgate prime 1200 watt amp install soon will that unit make it not as loud?
If you have to turn the gain way up on the amps, yes. That is bad.
I'm guessing those CVR's are going in a prefab too. That will also make things not as loud.
Having 2v preouts is not that bad. More noise floor but it's not like we still use tape decks. The MS-8 only has 2.8v preouts.
If you are using amps, its not the wattage you look for, its the preout voltage.
2 volt pre outs are completely fine, sure higher CAN be better, but really that's all you need. if you're really concerned about it buy a line driver..
2 volts is only fine if its a legit 2 volts. Most head units that claim 4 volts barely even do 2 volts. Let alone the cheap ones that claim 2V that doesnt make it past .5 clean
Wasn't that long ago when 1/2v pre outs were standard and people built perfectly good quality noise-free sound systems. 2v is fine.
In regard to running speakers directly off the HU -- That's definitely not their strong point. An 03 stock radio could easily have produced more power than the Jensen.
charleslatrelle
Nashville TN
n2audio
