Does size matter?
Ok i get it I don't have a computer so I have to use this as next best thing but would this be enough box for two 18
It would be going into a hhr
That's enough for one 18.
Better off with two 15s in that space.
You need to do a 15 that will work in like 3-3.5 cubes. You have 8.86 cubes internally, so unless you go with aeros, I'd say you'd have about a 1.5-2 cubes in port displacement if I had to guess.
---------- Post added at 09:21 PM ---------- Previous post was at 09:20 PM ----------
How much power do you want to run?
Bigger surface area pushing more air.
Roughly, 1 18 = 2 12's, 1 15 = 2 10's as far as cone area goes. So say if you went with a 15 instead of a 10, you might be twice as loud, theoretically. You see?
Is that for the most part true? (obviously I didn't know) that's interesting to know. (I know its not exactly the difference)
Well just simply taking the surface area of a circle:
8= 50.27
10= 78.54
12= 113.10
15= 176.71
18= 254.47
So you can multiply these by whatever.
---------- Post added at 09:45 PM ---------- Previous post was at 09:45 PM ----------
But remember Sd (t/s parameter) is the effective piston diameter/surface area.
Colossus281
Colossus281
Albuquerque nm
Papermaker85
