Umbra
Hobbyist & CA Tenderfoot
When I first went about setting gains on the amp for my subs I started with the head unit volume at 35 (out of 46; 75%) as that's what the guides I was reading recommended. The subs were added to a system comprised of the four stock speaker and an aftermarket head unit. However, the head unit only has a single pair of RCA outputs, so if I wanted to max the bass the volume needed to be at 35, which was a bit too loud for me. What I ended up doing was choosing 30 as my new max volume and turning the gains up on the amp a bit more. I used an oscilloscope, so I can see it's not clipping.
I'm going to be reevaluating this, as I'm replacing the stock front speakers with a pair of amplified components. This got me thinking, to what extent does it matter what you designate as your max volume? Hypothetically, let's say you wanted 10 to be your max instead of 46. If you were able to set your gains appropriately, how would this play out acoustically and electrically? Would it be the same as having 35 be your max?
My hunch is that you want to push your head unit as much as you can without distorting, thus decreasing the gain setting, and possibly decreasing the amount of power you'd need, which also makes me wonder to what extent preout voltages matter. I don't know; I don't fully understand how this stuff works, but that's why I'm here.
Can anyone enlighten me?
