Does anyone know how much my zapco 9.0 will put out at 6 ohm load?
If the answer is that important to you than why dont you take a clamp meter and measure for yourself?
Considering all amps put out different amounts of power even if they are the same model the only way to know for sure is to put a meter on them and then calculate watts.
If they're wired for 4 ohms, I'm going to assume that you want to know how much power you'd get if you removed one?
Also the easy way to figure out the power at a different load rather than going through the pain of figuring the voltage and then refiguring the power for the new load is to simply multiply the power and the load together and divide that by the load you want to know. That will get you in the ballpark at least. It fails to account for reality and losses but it is correct per Ohm's law.
trunks9_us
trunks9_us
college station tx
helotaxi
