dodge ram quad cab .. any hints?...
cheeseburger35
i'm halfway through building an entire fiberglass box for a 9510 under the backseat of my ram however i've got 3 aq hdc18's that i'm having trouble selling so i'm thinking about yanking the seat and putting those in would be a lot easier to put the amps/batts in a better spot as well... anyone ever do something crazy in these rams and know what they peak and and such? ... will be daily but probably an adjustable port so i can compete if i get the hair .... if i do this i'm going to pick up another 18 and do 4 on 2 powerbass 3k
I have an '04 quad cab and have had my back seat out for a while. I did a half wall with three MJ-18's tuned to 32hz on a measly 1kw. Peaked at 57hz. Went for spl with a 21" Autotek sub and peaked at 57hz again with a 52hz tuning...they seem to peak in the mid-upper 50's.
Right now mine = less than everyone //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I'm just working with a single 10" right now...still have the back seat out though. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
whats the max box we can fit in these trucks airspace wise? without having to do a wall .. i was thinking doing a half way with subs firing forward and port up ..? i'm looking i'm probably going to take the door off and try to squeeze the box in straight
Taking the door off will definitely give you some more depth. I wa sable to fit 52"x32"x18" through the door. I'm sure you can get a couple of more inches in depth if you took the door off. I was still able to see out of the back window with that setup.
where did that box hit the back window? ... how much room did that give you between seat and box? i've also been thinking about doing 2 boxes or maybe even single boxes and attaching them together with an extra front and rear baffle to get some more airspace.... i would really like to be able to squeeze 5 cube net per sub and that would be better if i did 1 or 2 boxes instead of 4 for sure
cheeseburger35
cheeseburger35
Okc, Ok
cheeseburger35
