Do I need a crossover?
  • 3
The passive XO doesn't bandpass the midwoofer, simply low passes it. This simply means your midwoofer will play into the subbass region. If your HU has a HP crossover, you're set. If not, it's not a big deal, but it would help matters if you had a HP at around 60-80hz.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
401
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
318
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
715
11
563
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
chase297
chase297
West Hartford, CT
chase297
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
