dmm or o-scope?
if you can afford the o scope you want that. that is the best way to set your gains becuase it shows you your sine wave and when it starts to clip
A DMM (or at the very least, a VOM - volt-ohmmeter) is a requirement if you want to do your own work on any kind of car audio installation. There's simply no excuse not to have one.
And not for setting gains, either.
x2 you will find yourself using a dmm all the time with various instalations. the o scopes you may want to look at are portable hand held ones. they have some good ones on parts express.com and i believe most of those portable ones will include your other need feature, voltage read, ohm read, etc.
2 totally different tools, only get an o-scope if you want this to be a profession, hobbyists don't really need one. a DMM with probes or a clamp works just fine for just about every application you'll encounter
if you can afford a portable one theres no reason not to get one. a full oscilliscope is a little overboard to set your gains but either way the dmm and clamps method is never 100 percent perfect and nothings easier and gives better results then seeing the sine wave on the o scope, and that you have clean unclipped power
If you know how to calculate the RMS voltage slopes of the signal, you will know roughly when you're clipping with a DMM. Thank you trig/calc.
Only if you can trust the amp's specs are 100% accurate. An o-scope will tell you when it clips no matter what the manufacturer says. But most of the replies above about needing a DMM anyway, and an o-scope not really being essential unless you are a pro or serious hobbiest, are correct imo.
hockeytoker
hockeytoker
Highlands Ranch, CO
FatPat*da*Ratt
