SOLD DLS Reference Ra20 Used $200
  • 2
Scott@GZUSA
Pro Seller
Supporting Vendor
200
St. Louis
This one is used, but in pretty good condition. It had a cap that exploded by the power supply, like that when I received it, so I replaced it along with the one in parallel with it so they match with Nichicon caps. It has also had some other caps replaced with some Wima caps fro the hell of it I had laying around. Same major specs just higher uf, I asked the DLS technician if it was ok and was told yes it would be fine. I also have the schematic if you are interested in those also. Amp works flawlessly. Make great power and sounds awesome. I guarantee it to work like new.
The sink has some scratches on it, nothing to major. I tried to show them in the pics the best I could.
$200 plus shipping, this is less than half the price you can get one on the web for
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 130 W
Output power in 2 ohm 2 x 200 W
Mono bridge mode 4 ohm 440 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,2 - 7 V
Input impedance > 10 kohm
Input impedance, high level 330 ohm
High pass filter 20 - 150 Hz
Low pass filter 40 - 125 Hz
Grand bass filter 0-18 dB @ 40 Hz
Low level output No
High level input with auto start Yes
Power consumption (idle) 0,6 A
Power consumption (max) 50 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 25 A
Dimension (W x D x H) 359 x 245 x 59 mm (14,1 x 9,65 x 2,33 inch)
Weight 3,8 kg ( 8,4 lb)
http://i62.photobucket.com/albums/h113/StlCreepin/DLS%20REF%20AMPS/Picture070.jpg[/img}
good guy here. i bought my dls a4 from him.
this amp is pretty tempting. i feel i could use a few more amps in my install
Thanks bud, if you feel the urge to get some more, hop on this deal, as I have never seen one sold for less, great amp for the money
Oh i know, this is a hella good deal. I could use a pair of these and run one to each mid in my car //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I am def considering this lol
I have a NIB one also, so it could be your lucky day //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I also have the matching Ra10 mono.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Scott@GZUSA
Pro Seller
Supporting Vendor
Scott@GZUSA
St. Louis
Scott@GZUSA
    May 20, 2024
    May 20, 2024
