This one is used, but in pretty good condition. It had a cap that exploded by the power supply, like that when I received it, so I replaced it along with the one in parallel with it so they match with Nichicon caps. It has also had some other caps replaced with some Wima caps fro the hell of it I had laying around. Same major specs just higher uf, I asked the DLS technician if it was ok and was told yes it would be fine. I also have the schematic if you are interested in those also. Amp works flawlessly. Make great power and sounds awesome. I guarantee it to work like new.
The sink has some scratches on it, nothing to major. I tried to show them in the pics the best I could.
$200 plus shipping, this is less than half the price you can get one on the web for
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 130 W
Output power in 2 ohm 2 x 200 W
Mono bridge mode 4 ohm 440 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,2 - 7 V
Input impedance > 10 kohm
Input impedance, high level 330 ohm
High pass filter 20 - 150 Hz
Low pass filter 40 - 125 Hz
Grand bass filter 0-18 dB @ 40 Hz
Low level output No
High level input with auto start Yes
Power consumption (idle) 0,6 A
Power consumption (max) 50 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 25 A
Dimension (W x D x H) 359 x 245 x 59 mm (14,1 x 9,65 x 2,33 inch)
Weight 3,8 kg ( 8,4 lb)
http://i62.photobucket.com/albums/h113/StlCreepin/DLS%20REF%20AMPS/Picture070.jpg[/img}
Amplifier class AB
Low level output No
Fuses 2 x 25 A
