Sold DLS IRIDIUM STUFF DOME MIDS TWEETs and PASSIVES, ARC AUDIO 2500XXK
newtitan
1) Arc Audio 2500XXK
one opf the many things I buy, and never use lol, I guess me and arc were never meant to be
was going to run all arcs, but its too hard to collect these things for a good price, and Id rather spend 1K on speakers vs, 1K on amps
very nice amps im sure, but the cost for me to get three of them is out of the question lol
anyway a absolutely mint 2500xxk
410 shipped , insured signature required.
I can take pics, but if youve seen these they dont show very well in pics due to all the reflections and whatnots
those are reflections off the wrappng bubbles on the top RH corner, and thats my big ol buddha belly lol
I dont have the original box, all the screws intact, fuses intact, serial number intact, never opened.
2) DLS IR3 dome midranges
too big for the dash of my truck, better for door panels, or kick panel installs
$110 shipped
these are used, and not mint. There is sawdust on the cone, didnt know the dome coating attracts sawdust--wheni was cutting the baffles. The grilles have a few sharpie marks on them, would look best if someone repainted them or something
basically about 6/10
but they work perfect 10/10
2)set of DLS Iridium 3-way passives
these are brand new in the box, no scrathces, MINT
$125 shipped
please note that there are TWO passives per side (so there is a total of 4 passives)
3) set of DLS UR1's
these are not mint, but would work, for say rear fill or something I guess
$40 shipped
there are small indentation in the cones, near where the diaphram meets the plastic. I have no idea how they got there, as when I pulled them out they were. They work perfect, but I assume that there will be a change in the dipersion pattern, there is some sawdust on the plastic. If you have one of those small vacuum for a keyboard, im sure it will pull the dent out rather easily
I think thats about it
let me know if you have any questions
heres more tech info on the dome midranges sizes, specs etc....
http://www.dls.se/english/speakers/Iridium%203.htm
Speaker type : 75 mm (3") doped fabric with chamber
Power handling capacity : 100 W RMS / 160 W max
Impedance : 4 ohm
Fs, resonant frequency : 280 Hz
Voice coil : 75 mm / 3" Aluminium flat wire, 5 mm
X-max : +- 0,5 mm
Frequency range : 250 - 8000 Hz
Sensitivity : 91 dB (1W/1m)
Magnet size : 80 mm (3,15")
Outer diameter : 120 mm (4,72")
Installation depth : 35 mm ( 1,38")
Mounting hole : 95 mm (3,74")
newtitan
newtitan
CALI
newtitan
