Sold DLS A6 & IRIDIUM 6.2 | TREO STREETBOX12 & SSi 12.44
EmEsDub
I’ve got some high-end gear here for ridiculously low prices. Local pickups are available in OC/LA area. If item is shipped, buyers pay ALL shipping fees plus additional 3% for PayPal.
For now, prices are FIRM, and Low-Ballers need not apply. E-mail me if you’re interested at emesdub@gmail.com.
1) DLS A6 CLASS A/B MONO AMP | $320 FIRM (each) | BRAND NEW (2 available)
1200W @ 1 Ohm Mono
2) DLS IRIDIUM 6.2 6-1/2” 2-WAY COMPONENT SYSTEM | $400 FIRM | BRAND NEW
3) TREO STREETBOX12 (LOADED w/ SSi 12.22 SUB) | $300 FIRM
This box was used for LESS than a week--sub isn’t even “broken in” yet. Seriously, it has LESS than 2 hours of play. Perfect working condition and 9/10 cosmetically.
This is an ORIGINAL Treo box factory-loaded w/ an SSi 12.22 12" sub. It's got a brushed-aluminum front panel w/ Treo logo etched on top. It's a 1.75 ft^3 ported enclosure tuned to 28Hz. Sub is Dual 2 Ohm version and conservatively rated at 750W RMS--but can easily handle more.
4) TREO SSi 12.44 12” SSi SERIES SUB | $200 FIRM
This sub was mounted, tested, then never saw power again. It’s practically brand new—not even “broken in” yet either. Perfect working condition and 10/10 cosmetically.
Sub is Dual 4 Ohm version and conservatively rated at 750W RMS--but can easily handle more.
Possible interest in the Treo with box, I don't know much about these could you give me some similar subs as comparison, your suggested power, or where they excel in etc.
Hmmm... IMO the Treo 12" SSi is comparable to the RE SX, it also can be compared to the JL 12W6v2 or even IDMAX12. The SSi can/will probably get louder than the W6 and MAX--but wouldn't be on there level as far as SQ. SSi's SQ is pretty dam good if you ask me, but the MAX and W6 are just remarkable in that department.
Power handling on the SSi 12 is 800W RMS. This is a VERY conservative ranking--as I've seen it handle 1500W daily. Ideally, you wanna feed the sub between 600-1000W RMS.
Do some research, I'm sure you'll find nothing but good words about Treo. They're normally pretty pricey, but you'd be getting a deal at this price.
EmEsDub
EmEsDub
SoCal
EmEsDub
