Distro blocks.
miker
I am looking to buy two distro blocks for my power and ground. I am currently running 4 gauge to one of my amps and 8 gauge to my other amp. The only distro blocks I can find are, 4 gauge->8 gauge, and 1gauge ones.
Would it work to run the main wire as a 4guage, and the other two as 8 gauge? Or do I need a beefier cable? The max I will be running is 300w rms for one amp, and 1700w rms on the other.
What does 0/1 stand for? o/1 gauge? If so I have no 1 gauge cable... Would it work to put 4g in a 1g spot? I mean it's held in by a screw so I can really only see problems with it if the opening is to small.
Thanks
KonFUSED 3 Way Distribution System
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-23 has two input ports, which by changing the Kompression Fittings, can accept 4 Gauge or 1/0 Gauge Cable . The two of the three ouputs can be adjusted to accept 4 Gauge or 8 Gauge cables while the last output can be configured for FUSED 1/0 or 4 gauge output .
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-23
miker
miker
Wayzata, MN
jco1385
vegang
vegang
