Distribution blocks
  • Thread starter von
  • Replies 0
  • Views 398
von
Hey guy's or gal's, I am using a tsunami dual amp wiring kit, to hook up my new system, according to th specs it comes with an agu distribution block,a positive- negative distribution block, and a ground distribution block, my setup is as follows.a priemer deh-600ub head unit, alpins pdx 5 5 channel amp,alpines pdx-4.150 planning on bridging to 300x 2 using 2 12 inch xsite subs until I buy of alpines 10 inch type r subs,as for the front I have alpines spr-17s components, and alpines spr-69c at the rear panels.will I need all three distribution blocks or is it just alot of clutter?also using the 5th channel on the pdx5 for one sub the 2nd amp for other 2 subs school me on if I should bridge the pdx-4.150 which would be 300x2 for the two remaining subs or should i go with a 600 watt mono for the other subs? this is my first system.
von
von
wakefield neb
von
