Distortion?
undeadxsunshine
what it is
So I got my setup installed that's in my sig, and got all my gains set. When I turn it up to where it starts getting really loud, and the song has somewhat heavy bass it starts to get distorted I think. Of course this should be normal, but the thing is it doesn't sound like normal distortion, it's more of an occasional "click" sound. Is this normal or is something not set right?
o yeah i cant belive i didnt think of this before.. but could it possibly be tinsel slap? (which hpf should help) i dont know if those speakers have stitched tinsel leads
Gains were set correctly with a DMM, so that's not really the problem.
No they weren't and yes there is.
Don't set your gains with a DMM, it's silly. Would you believe the police if they wanted to give you a ticket for speeding based solely on how fast they thought you were going without a radar gun???? Using a DMM is worse than that.
Turning on the high pass filter can help, but if they are full range speakers, you shouldn't have to. The damage could already be done, but make sure all of your wires are tight so that your amplifier is maximizing it's ability to control the speakers. I have seen this happen when someone trys to put to much base into speakers without enough power or trying to make a speaker do something it is not capable of. A good set of components will handle a lot of power and produce a good amount of base. I have some infinity perfects and they take a lot of power. I don't have anything else on the amp with them either because I want them to be powered properly.
Didn't know that using a DMM was that bad, from what I've read on here it seemed like the right way to do it. It actually did turn out well though with them set like that. I only get the noise with a few songs super heavy bass, and only when it is up really loud. With the filter turned to high I didn't get the noise, but I also didn't try pushing them that hard. Bottom line is once I get a sub to take care of my lows I can filter out more of the lows to really make sure none of this happens.
undeadxsunshine
what it is
undeadxsunshine
York, PA
undeadxsunshine
