Distortion
Techchild
Not a racist.
Hi,
I have a 95 del sol, I just wired up a crunch pzi100.4 to my speakers with 4g power wire and 14g speaker wire all stinger hpm series. The problem is depending on how the rcas are set up it's either really quite or alot of really loud distortain even with the volume on the head unit turned to 00. I tryed changing the direction of the rcas no luck I tried changing from left to right top to bottom also no luck. Does any one know the solution to my problem?
that would be a very smart thing to do... IMO
does it do it with the car running or with it off?
did you take the ground surface down to bare metal? because it doesnt look like you did...
it does it when the car is in accesery when the gain is all the way down. It only does distortian when it is in the first key position when you touch the gain.
not sure if im seeing it correctly but did u ground the amp to...the back seat??if so move that asap and ground it to your chasis...
Two seater and that is a metel wall attached to the frame.
Also found out it is the headunit rca output making all the noise.
And my mom threw out my reciets //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
check the connections inside your amp were the rca is soldered to the board. i have had the same issues and it turned out the solder broke and a quick touch with a hot solder iron fixed it.
Techchild
Not a racist.
Techchild
Middle school locker room
Techchild
