directed 2400d
right now i have a 2 single 4ohm subs wired to 2ohms
what would the ohm be if i added another single 4ohm sub
would it work off this amp, to get its full 1200rms at 1 ohm
so you have the new version directed amp? I thought you had the amp I have the older version which is 2400d which is actually 2400 watts at 2 ohms not 1200 watts at 1 ohm... if you add 2 more svc 4 ohm subs then yes it will be down to 1 ohm load.
it says 800rms at 2 ohms; 1200rms at 1ohm
must have older one then
when i looked at a chart it said liek 1.37 load can that work on this amp? and if it is not completly 1 ohm load liek example .37 more will it still put out the 1200rms.
snick
snick
michigan
snick
