digital d esigns c4 silver and black
  • 1
cal
ddc4
The DD C4 series amps are clean, solid and well built amps, individually tested for reliability.
It features double sided boards, high quality 24 dB/oct xovers, large connectors, heavy heatsink circuit board buss bars for high current delivery and remote gain controls for subwoofer use.
The DDC4 is designed in America by Digital Designs.
2 X 150W + 2 X 75W 4 ohm stereo @ 14.4V, 0.5%THD
2 ohm stable
MOSFET power supply Gold plated terminals
Dimensions: 220X61X380mm
Stereo: 75 x 2 @ 4ohm + 150 x 2 @ 4 ohm,
Mono: 250 x 1 bridged @ 4 ohm + 450 x 1 bridged @ 4 ohm
used , amp is fully working no issues. amp is active capable and is a pure beast, had this running 4 ddvo 6.5 and a pair of crescendo ft-1 and it sounded great . amp never came with mounting feet so i made some they were a quick mod but work well . dont have the original box, manual or remote
250 shipped con u.s. no trades
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
cal
cal
cal
    May 31, 2024
    May 24, 2024
