difference in output on a 12 or 15
Alejandro14
will i hear a difference between 2 sundown x12 or 2 sundown x15 ? if yes in what way would i hear a difference ? i just cant deside due to space on my back of my ford f150 extended cab ' i have like 4 to 5 feet on back width and length like 7 feet ' i just dont want to block rear window ' any suggestions thank you
so you guys recommend me to get 2 15s over the 12s .... and how much power can this speakers handle ? should i go .5 or 1 ohm ?
yes 2 15's will be quite a bit louder as long as u have the correct air space and power for them.. Question is would u rather have some space left or just only care about spl..
2 15's just means more cone area vs. 2 12's. However, I've seen/heard 2 12's out due 2 15's. It's really gonna be enclosure dependant. Keep that in mind and do some max measuring 1st before buying.
for space i dont mind loosing the back space ' i ise work truck daily and jam maybe 3-4 hours when i drive ' i listen to decaf ' hip hop ' and all kinds of songs ' i want something that will play low ' as for box what you guys recommend for the 2 15s sundowns ' remember i am trying not to cover back window and i dont want to do a wall truck has 180000 miles dont want to break down on me ....
[quote name='Alejandro14']for space i dont mind loosing the back space ' i ise work truck daily and jam maybe 3-4 hours when i drive ' i listen to decaf ' hip hop ' and all kinds of songs ' i want something that will play low ' as for box what you guys recommend for the 2 15s sundowns ' remember i am trying not to cover back window and i dont want to do a wall truck has 180000 miles dont want to break down on me ....[/QUOTE]
You want lows, then the X series 15's will def do that. 8-10 cu ft tuned to 28-30Hz should make you and the subs happy. @Buck can get ya a good design for them.
got it ' thank you guys ' is 8-10 cuf box will cover my back window ... ? i will start with buying 1 then on 2nd paycheck i buy the other one ... so ill get them dual 4 ohm just to wire it down to 1 ohm ' with a 5k amp and tune to 30 just to not loose some 45 hz frequencies....
That's what I have, d4 ohm subs....wired to 1 ohm load. Where you plan on mounting the amp?
Alejandro14
Alejandro14
Texas
Jeffdachef
