Dieing of boredom
You know I'm ******* with ya man.. come here and work in this huge plant we are about to build, you can make about 10k a month as a helper..
If you make more than that, why not order a batch of your custom subs
Top helpers will gross 13k I'll probably gross about 17-18k a month. btw when you start school young blood?
I start school in August
More than likely will brother. If the buildhouse proves reliable and can get the design perfect. You can't just build something and say cool and mass produce it. Btw I'm making some small changes in the structure of the design. The buildhouse did some silly things I figured they had the knowledge but I had to revise it.. it's not really for performance but reliability.. this thing Pounds and sounds excellent I just want it to take more abuse..
i dont know what you're talking about that sub is just about the same as 95% of drivers in the same category triple stack magnet and extended top/bottom plate.
If you say so.. I've talked about the design aspects and how it's not like alot of drivers but I can only tell you how I chose to design it.
I'm dying of boredom right now while I wait for a script to finish geocoding 50k+ addresses.
You should get me a job if it really pays 10k a month w/ minimal experience. I wouldn't mind some cash to play around with as well.
Kmsl. These jobs take years off your life. It's stupid stressful. Electricians/instrumentation trades always get the **** end of the stick but the technology and science around it is ****** and the controls/programming is cool..
I applied to an engineering position. Would probably be a pretty boring gig judging by the description.
what language do you use? or is this agui based thing
Depends on the application.
C++,MATLAB, and Python for general use/computing/GIS
MySQL and PostgreSQL for databases
Javascript or Flask(Python) for front end.
For the most part though Python is generally my go to for general use. It's just so simple to throw something together most times. The script I'm running currently I wrote in Python.
What's the actual position
Engineering I - I just applied for the hell of it since it's the only one close by that I found in a short time. :p
The Camry
Hey, I Try.
The Camry
Western Oregon
adulbrich
