DRBagabundo
Hey guys, I have the following equipment installed in my car:
JVC-KW910BT headunit
Precision Power BA2200.5 5 channel amp
4 Scosche HD6503A mids
1 Alpine SWR-1042D sub
To connect to the 5 channel amp, I ran 4 channel(9 conductor) Speedwire from the Metra harness and taped off the speaker wires coming from the JVC unit's harness.
My headunit only has 4 preouts(2 front, 2 rear/sub). I also ran two sets of rca's from the back of the headunit, to the amp in the trunk. I connected the speaker leads into each of their respective channels(4) and connected the rear/sub rca's to the 5th channel.
I took the rca's off the front channel and added y-splitters to each end and connected then into the front and rear rca inputs on the amp since the amp does not have a input selector switch. I'm assuming this would give me mono signal instead of stereo, correct?
I also set the headunit to read the rear channel as a subwoofer.
Based off that novel, did I connect everything properly? Suggestions, critiques, anything would be helpful!
Thanks!
PS: My setup is changing real soon but I just wanted to get the best out of my current system.
Thanks!
