loknload
I have a 2010 Toyota Tundra with the tow package so it has a 150 amp alternator and, supposedly, a heavy duty battery. I installed pretty much all of my equipment out of my former 2008 Toyota Tacoma with the exception that I'm running the stock head unit with an Audio Control LC6i instead of the Alpine CDA-9887 that I was running in my Tacoma. My amps consist of an Alpine MRP-F450 (70x4 RMS) and a Soundstream RUB1.1000D (currently running 800 RMS @ 2 ohms). They're running Polk Audio Momo components in the front doors and stock speakers just for a little rear fill in the rear doors and two JL 10W1's in a ported box. Like I said, the only differences from my Tacoma to what I have now is the stock head unit and LC6i and that I'm running a ported enclosure, whereas, I was running sealed in the Tacoma.
My lights never dimmed once in my Tacoma and it had a smaller 130 amp alternator. I got all of this installed in my Tundra and immediately noticed my lights dimming when it was turned up moderately loud. I am running 4 gauge power and ground from distribution blocks. The first thing I did was checked my grounding point and made sure all of the paint was removed and bolted it back up. I then cleared all the paint from under the factory battery to chassis ground. It got better but the lights still dimmed. I had some 4 gauge and terminals left over so I did the big 3 by just adding 4 gauge to the factory wiring from the battery positive to the alternator, battery negative to the chassis (different grounding point than factory), and engine to chassis (different grounding point than factory). I also went back and checked my gains. The four channel has the gain about half way on the fronts and about a quarter on the rears. The sub amp has the gain just below half (set with a meter) and the remote bass control is about a quarter. My lights still dim when it's cranked up.
So my question is what's next? A 150 amp alternator should be plenty for there amps. In fact, I would've thought that my Tundra would have handled it better than the Tacoma with the stiffer charging system but I guess not. Do I try a battery next? Something like an Optima yellow top? The free and easy upgrades are over with and I don't want to just throw money at it and not solve the problem so I need some advice. Thanks.
