Diamond vs. FI.
I don't know if your amp puts out a true 1000 RMS, but if it doesn't get one that does.
Either way - I would definitely get the 15" Q in a ported box. You won't be dissapointed.
I went from 1 12" off 500 watts, to my 15" mag off 1000 and it is a huge difference.
Honestly i would go with the Q, the difference isn't that much between 2 12's and 1 15 in cone area plus the Q is more comparable to the d9 than the d6 so you'd have greater output, and get lower. I have a 15 fi Q which was an upgrade from my 2 12tc2+, just like the tc1000 and it gets alot louder and hit lower than my 12's did, while blending very well with my front stage.
P.S. they were both getting the same power 450 a piece to the twelves and 900 to the 15
I don't know if your amp puts out a true 1000 RMS, but if it doesn't get one that does.Either way - I would definitely get the 15" Q in a ported box. You won't be dissapointed.
pretty sure those amps do rated
I really liked the D6's that I had. They didn't like 2400 rms daily though. LOL whodathunkit? Seriously though, that D6 could use a decent amount more power. I'd prolly pick up another D6 12 and a 2000ish watt amp for the pair. It would be a nice setup
Q will outshine a D6 by a mile.........Havening owned both personally
My pair of D6s used to run off a D61500.1 , so I am assuming that 1000.1 u have would be too small
for 2 12s even though its an underrated amp
andrewibk
andrewibk
Orange County
Ignatowski
