Diamond D5 300.2. 300 rms bridged @ 4 ohm, 150x2 @ 2 ohm
Rc 415
I'd like to trade my black D5 for a D3 400.4 Preferrably, but let me know what you have, I need 4 chanel. This amp can be a great sub amp for a little sub that doesnt need much power, or a good amp for your comps. I have never powered this amp up.
D5 300.2
FEATURES
Technical
• Fully Regulated Power Supply
• Up To 5V RMS Input Signal Voltage Capability
• High pass x-over 12 dB/oct. 1.5 kHz-15 kHz Subsonic 15-1.5 kHz
• Adjustable Q with a 10 dB boost
• Low pass x-over 12 dB/oct. stereo 50 Hz-5 kHz, mono 24 dB/oct. 50 Hz-5
kHz
• RCA Outputs
• 2 oz. Silver Plated Copper Circuit Board
• Massive Proprietary Heatsink
Convenience/Appearance
• Fully Variable Electronic Crossovers
• Nickel Plated Solid Brass, Circuit Board Mounted, 4 Gauge Direct
Power/Ground Connector Blocks
• Nickel Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or
Banana Plug Direct Speaker Connectors
• Fly Cut Billet Aluminum End Plates
• Fully Adjustable Mounting Feet
SPECIFICATIONS
Frequency Response: 10 – 50,000 Hz
Signal-to-Noise Ratio: 100dB
THD: 0.03%
Channel Separation: 80dB (min.)
Input Sensitivity: .2 to 5V RMS
Input Impedance: >20k Ohms
Power Supply Operating Range: 11 to 14.5V DC
D5 300.2
75W x 2 @ 4 Ohm Stereo
150W x 2 @ 2 Ohm Stereo
300W Bridged @ 4 Ohms
D5 300.2
Length: 12 1/2"
Width: 12"
Height: 2 3/4"
Or will sell for 150 + ship.
Rc 415
Rc 415
San Francisco
Rc 415
