Diamond Audion d312 enclosure size
2Gemini
IL
*Just realized I spelled "Audio" wrong. Dyslexia FTL //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I'm getting ready to order 2 Diamond Audio D312.2 subs and have not decided between sealed or ported. (i will probably go ported though). The specs on Diamond Audio's website show this for the recommended dimensions:
http://www.diamondaudio.com/PDF/current/WiringEnclosures/Dual12VentedEnclosure.pdf
I listen to mostly classic rock and alternative, although I do throw some techno and rap in once in a while. So, should I use the specs on DA's website or go a different route? I've looked through the "free box plans" section, but can't decide what size and tuning would sound best for my application. I will have both the subs and port (if i go ported) firing into the cabin.
This will be my first box build, which I'm sure you could tell from my O-so-newbish questions. Thanks for the help.
Bump after a couple days.
Decided to go with a ported enclosure. Not sure of the Box Dimensions. Could someone offer a few opinions?
Thanks
2Gemini
2Gemini
IL
2Gemini
