Diamond Audio D61000.1 Class D AMP
HondaSI
Item(s) for Sale: Diamond Audio D61000.1 Amp Class D 1 OHM STABLE. Comes with Brand New Bass Knob (NEVER USE THOSE THINGS)
9/10 cosmetically. its been mounted.
10/10 mechanically. works great, no problems at all! LIKE NEW!
THIS IS DEF UNDERRATED!
Specs for you.
D6 Series Monoblock Amplifier
RMS Power Rating:
250 Watts x 1 Channel # 4 Ohms
500 Watts x 1 Channel # 2 Ohms
1000 Watts x 1 Channel # 1 Ohm
Massive Proprietary Heatsinks
Wired Remote Level Control Included
Nickel Plated Solid Brass, Circuit Board Mounted Terminals
4 Gauge Direct Power / Ground Terminals
10 Gauge Direct Speaker Terminals
Fully Adjustable Mounting Feet
Advanced Protection Circuitry
Adjustable Input Sensitivity: 200mV - 5V
Low-Pass Filter: 50 Hz - 250 Hz, 24 dB/Oct.
Subsonic Filter: 15 - 40 Hz, 12 dB/Oct.
Phase Switch: 0° / 180°
Dimensions: 11-1/2" L x 12" W x 2-3/4" H
$200/SHIPPED O.B.O
Will Ship UPS the following day after payment is received.
UPDATE!!
Item(s) Description/Condition: 9/10 cosmetically. its been mounted. 10/10 mechanically. works great, no problems at all! LIKE NEW!
Missing 1 Speaker terminal screw not needed but can get another one from fasenal or bolt And nut shop..
Specs for you. D6 Series Monoblock Amplifier RMS Power Rating: 250 Watts x 1 Channel # 4 Ohms 500 Watts x 1 Channel # 2 Ohms 1000 Watts x 1 Channel # 1 Ohm Massive Proprietary Heatsinks Wired Remote Level Control Included Nickel Plated Solid Brass, Circuit Board Mounted Terminals 4 Gauge Direct Power / Ground Terminals 10 Gauge Direct Speaker Terminals Fully Adjustable Mounting Feet Advanced Protection Circuitry Adjustable Input Sensitivity: 200mV - 5V Low-Pass Filter: 50 Hz - 250 Hz, 24 dB/Oct. Subsonic Filter: 15 - 40 Hz, 12 dB/Oct. Phase Switch: 0° / 180° Dimensions: 11-1/2" L x 12" W x 2-3/4" H
Price: $280/SHIPPED O.B.O
USA ONLY
Shipping and Miscellaneous Item Information: Will Ship UPS the following day after payment is received.
Item Pictures: (List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).
HondaSI
HondaSI
ohio
HondaSI
Mike Mccabe
