DEH-P7700MP question
ok heres exactly the full problem. Bear with me :p
I was searching google for a pioneer harness that will fit my pioneer DEH-P7700MP as seen here http://www.crutchfield.com/S-osLkGwm...130dehp770#Tab .
I have a brand new GM harness (95 chevy s10 ext cab) and I am going to easily install this. I then will purchase the right harness for the reciever itself, and connect the two. 1 problem. I cant tell which harness off of the lists harness http://www.installer.com/wires/pioneerwire.html that you have fits mine. To poorly explain it. Its got 7 small holeso n the top and bottom w/ 1 larger hole on the end. Then it has 8 slots that are rectangular shaped in between those two rows. I've been trying to take a best guess and I think it might be the WH-P16M model. Can you check into this for me and make sure I get the right one? One last question. Between the original harness for the reciever and my GM reciever. There is a Clear 18 pin adapter if you will call it that. That adapter splits into two. 1 side connected to reciever harness. And the second half of adapter connected to the GM aftermarket harness. Where can I get a new one of those, if so can I use the one I have? The wires are all cut up and its not matching the amount of wires going to the otherside. I would need about 36 little metal pins that go into it tho and connect them to the wires. Id rather just buy a new one personally, assuring they'd all stick in. Please help, adn hopefully I can buy the harness from you guys.
this might be a little late but if your looking for the wire harness that comes out of the 7700MP you can get it off
http://parts.pioneerelectronics.com
or call 1-800-421-1404 (location California)
the part number SHOULD be XDE7007 - Description - Power W/Speaker Cord Assy
and it cost $15.64... it fits a number of pioneer head units but also fits the 7700mp, i'm looking at the part number off the receipt i have when i recently (in may) purchased a new one for my 7700mp as the old harness was damaged by flood waters(corrosion in the plug).
if you need the mounting sleeve it is part number CNC8659 - $10.56
the remote control part number is CXC2665 - $30.43
tzk0nlin3
YoUr FathEr
tzk0nlin3
McKeesport, Pennsylvania
2loud4u
