Decisions...
hmm i was actually mulling the same decision but ended up with the JL because the fact that the 450/4 has so much power. Typically JL underrates their amps about 10-15% while audison typically is dead on on their ratings. JL isn't shit either so i went with headroom over Italian sexiness.
Is all 4 channel amps full range amps?? I was reading that full range amps r the best too run speakers.
sub amps which are typically class d amps are not able to reproduce certain frequency ranges. usually those sub amps produce somewhere between 20hz and 300hz or so. while the frequency range is 20hz to 20khz so these amps aren't full range amps. Full range amps can reproduce the whole frequency spectrum so you want these amps because you want your mids and highs in your car right?
YES SIR...
I got some Focal165K2P {Front} Focal 165CV1 {Rear}
dumblude
dumblude
Houston,TX
dumblude
BP1Fanatic
BP1Fanatic
