AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
alright ill be looking for ya
I used 4" Aeros
What the hell did you say ska?
Finished the install
Exterior:
Interior:
im lost... what are u talking about Chris? lol
squeak you tested it any yet?
No, I worked until 5.30 today and then it was dark and COLD. Im going to finish tomorrow. I get off at 12.30 and got all day to do two small things. Should be done by 2 EASILY.
better fire it off and make sure all is fine.
Unless something is wrong in the rex, it should be fine. I used the subs box and amps in my car for a test the other day.
Well I just finished it all except the remote wire. I gotta go get some spade connectors for the switch and then Ill be done.
Ports back was too hard to load the box in by myself, so Ill probably leave it like that, not sure though.
I would try to get ports back or even to the side if you can. I have seen 2 db jump between having the ports firing forward and then pointing them to the side.
Well it works. I tested it on the radio since I haven't made a CD yet. Also I locked the keys in it, but I'm a hella crook and saw something in the door when I popped some molding off. Looked like it needed to be pushed and when I did, it unlocked the door //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well I'm about to burn a cd, flip the box around and extend the speaker wire with wire nuts.
good job squeak,heres my score on the term i done today during testing,db drag style,engine off,legal on the dash.
Will someone there have some sweeps? My burner wont burn the ones on ROE. I just need 50-70
i got some sweeps,and by the way why is one aero port longer than the other one.
A variation of a 6th order bandpass.
