deadeners
out of all the brands mentioned so far the best are as follows (in this order)
Dynamat extreme 1.7 mm thick 300 heat tolerance
Brown Bread 1.51 mm thick 293 heat tolerance
Edead 44 mils thick 200 heat tolerance
Fatmat 45 mils thick 180 heat tolerace
Peel and seal 40 mils thick 150 heat tolerance
ANT
"PEEL-N-SEAL works with full efficiency in a range from an amazing frigid 65° below zero to 180° F."
Quoted straight from their website.
god I'm sick of this...but i have it mine and love it...its super cheap, doesn't smell, and does its job of deadening..BOTTOM line...
I've used a handfull of deadners and notice no change between any of them...p @ s is better then fatmatt IMO..the fatmat peeled away alot faster then the p @s...dynamat extreme was fine but WAY expensive, glad it was free...what a waste of money!!!....
all this bull shit about p@ s is about install...if you dint no how to do it , it's obviously gunna turn out like shit and peel....duh!....i've used enough to no whats crap and its NOT PEEL N SEAL....
0 SMELL
"STICKS" WITH THE BEST
AND DOES ITS JOB!!!!!!!!!!!!!!!!
ighettoboyi
Shot Caller
ighettoboyi
mean streets of OC
audioholic
