DDm3 Bench test
hell here
When you halve the impedance, the power doesn't magically double. You draw more current, produce more heat, and the amp is a considerable amount less efficient. Hence the drop in power. Those are real world tests, not some bullshit bench test for a quick burst of power on a static resistor on a constant 14.4V or whatever.
If you read, it said it dropped to 13.8V, so that combined with the loss in efficiency for running at 1 ohm, it's not that hard to believe.
yes it does if the power supply is adequate, in this case it looks like the output likes 14+ volts..
inductive loads aren't the same, but it gives a good idea..
seems as it will do 2400 @ 14.4, but they need to upgrade the power supply and raise the rail voltage..
hahahaha, power supply in adequate...you might wanna look at the inside of this amp and understand a little more, the supply side of this amp is grossly over built....
This amp will make above stated power 4k+ driven into lower impedances, and around 2700rms at 1ohm
hahahaha, power supply in adequate...you might wanna look at the inside of this amp and understand a little more, the supply side of this amp is grossly over built....This amp will make above stated power 4k+ driven into lower impedances, and around 2700rms at 1ohm
This.
A little current hungry at 1/8ohm dcr too. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Andrew_as
Andrew_as
Topeka, KS
Louisiana_CRX
