DD3515 with carbon fibre dust cap dual 2ohm
i have purchase a DD3515 with carbon fibre dust cap dual 2ohm from a friend,can some one please let me know the full speaker parameters as i cant seem to find for dual 2 ohm version.also can any one tell me its rms have seen roughly 1200 rms does carbon fibre dust cap increase rms if so how much?.need to no how much is speaker displacement for one of these drivers,also i have about 40.5 inches width 14 inches deph 16 inches height external 1inch all round 2 inch baffle roughly 4.45cft with out speaker displacement. not sure on what the best tuning for dd3515.i want to be as loud as db possible and low damm low i want to be playing music 140 db plus do you guys think thats possible? all help thanked in advance.also can anyone tell what motor is fitted from pictures.all help thanked in.
can you tell what motor is fitted from pics? weight of speaker was 11kg magnet was 3 inches rough height. weight 388 ounces
sorry copy past job
thanks misfit138 i been asking about lol.
found 3 stickers hope this helps.
11-2004 i know this one build date
DD35K 2/2 not sure about this i no its dual 2ohm dont know what k means
11445 dont know what it means
thanks misfit138 i been asking about lol.found 3 stickers hope this helps.
35K is DD's 3500 series subwoofers
serial number
http://www.ddaudio.com/dd/default.asp heres the link to dd it will give u all the info u need for that sub there boxs usally tune to like 45 hz so that u get a wide rang of hz for music, with the right box and depending on placement and car u can probly get to the 40s
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
DD35k means 3500 series. The 2/2 is Dual 2 like you said.
I would start at DD's site and see what they say. depends what your willing to loose for space.
The rated doesnt really mean a whole lot with DD. More important is user knowledge. I personally would throw 2k to the sub. Just make sure your not clipping or anything.
came up with this let me know if this is ok any and all help thanked in advance.
ext-18 (h) x 14- (d) x 40- (w)
int-16 (h) x 12- (d) x 38.5- (w)=
7392 cu in/4.277 cu ft/11977 litres
7392 x0.77 =5691.84 cu in (0.77=spk+port disp.
5 x corner dispersion(32 cu in ) =160 cu in
5691.84 -160 =5531.81 cu in /3.2 cu ft.
3.2 cu ft x 16 =51.22 sq in divided by 16 =3.2 inches wide =77mm port width.
internal L vol. box after spk/port/corn disp.
=3.2 cu ft
=5531.81cu in
=89.6 litres .
thecat666
thecat666
london england
thecat666
