Sold dd z se amp 30 of 50
Anyone else notice these are the same power ratings as the AA500.1
Also, from what I heard, DD didnt continue with these amps because the build house lied about power output, besides, the M4a is rated for more power.
Anyways, good luck from a fellow DD nuthugger.
Well I think you need to re-think what you think you know. I owned both the m4a and the Zse amp. I tested them both. The M4a made 6.1k at 12.3 volts at 1.5 ohms, and the Zse made 5.9k at 12.3 volts at 1.5 ohms. But the more batts we added the Zse began to catchup. So I dont know what the heck you are talking about. I agree a lower voltage the M4a makes a little bit more power. But when you add power the Zse begans to catchup. If we had a continuous power supply, I would bet the Zse would over run the M4a!!
For the M4a and Zse used 2 kinetik (shurukens) type batts, to get the initial power reading. But we added a g3100 and the Zse began to close the gap. But right now I dont have the exact numbers on me.
scott s
scott s
york.pa
scott s
